Loaders on Rock Island Tractors
Gene Dotson
02-05-2007 19:12:36
I have seen many requests on here about putting front end loaders on the Rock Island built tractors.
Would like all to know about the weak front engine mounts to the front bolster. These front mounting bosses can break if the force and load is great enough. The engine is the entire frame in this area.
The fix is very simple to reinforce this area. Use a 3/4 inch thick flat steel bar on each side of the engine from the front bolster casting to the bell housing casting. The plate needs to be wide enough to allow the drilling of the 2 holes on each end to allow it to be bolted on.
This will take all the stress from the front of the engine and prevent a very expensive break.
These tractors are from the VA series up through the 630 series... Gene
BarryfromIA
02-05-2007 20:47:59
 Re: Loaders on Rock Island Tractors in reply to Gene Dotson, 02-05-2007 19:12:36
Hi folks, These tractors need a full frame. The factory construction loaders mount in the 4 front 3/4 in holes and the rear axle. Same as the factory farm loaders That CASE sold.
