case va4 civil defense tractor info wanted
tim coltman
02-05-2007 07:32:16
hi im going in a cuople weeks to get a case va4 civil defense tractor. i dont know much about case tractors this will be my first one. i need some info on it what years were these produced and any idea of how many? what is the horsepower for it? color scheme? i have searched a bit for info but cant find any thanks for any and all help. tim coltman
Jerry W
02-07-2007 05:51:41
 Re: case va4 civil defense tractor info wanted in reply to tim coltman, 02-05-2007 07:32:16
I am not familiar with Military Case at all. Does anyone know if that cab is factory? or is it an add on. Tractor looks fairly ordinary VAI. Serial number would be the answer - I would like to see it. Wheels weights are non standard also - are they Case? If the cab is OEM then that would have to be worth more than the tractor.
Jerry
'53 VAI Guy
02-05-2007 17:05:33
I agree with Watsons. Looks like your basic VAI (Industrial) with a cab. I dont believe its a VAIW (warehouse) as it is lacking alot of the signature metalwork (running boards and push bumpers) as well as the smaller tires used on the VAIWs. The VAI tractors were also utilized for military purposes and I would not doubt it if many ended up in our Civil Defense system as well. My 1953 lived much of its life (up to two years ago) as a municipality tractor (state, then local). Good luck.
watsonsgotit
02-05-2007 14:40:13
What you are looking at is simply a CASE VAI that has had a cab adapted to it. There are many VAI's out there, you generally don't see them with cabs though.
bcdave
02-05-2007 10:44:36
Is that a VAIW 4? Tugger? If it is there are pictures on this site.
dave
tim coltman
02-05-2007 12:12:06
 Re: case va4 civil defense tractor info wanted in reply to bcdave, 02-05-2007 10:44:36
third party image
here is the only pic i have of it so far if it works i havent tried to put a pic on yet. i dont know if thats what it is it could be. and i couldnt find the pic you said was on here i looked through all the case pics. tim
