Difference between 930 lp and diesel engine
Gholveck
02-04-2007 16:44:36
I have a 930 LP it has the 377 six cylinder. But the block looks the same as the 401 diesel. Does anyone know the differnce in the two. thanks
Gene Dotson
02-05-2007 04:10:19
 Re: Difference between 930 lp and diesel engine in reply to Gholveck, 02-04-2007 16:44:36
The blocks are essentially the same with the LP block being machined for a distributor. Pistons were same height between diesel and gas. Camshaft was different with drive gear for the distributor.
The stroke length did not change and all are 5 inch. Bore sizes are 251 and 377 at 4.00 inch, 267 and 401 at 4.125, 284 and 425 at 4.25 and 301 and 451 had a 4.375 bore
Case used the 5 inch stroke all the way to the 336 and 504 engines of later years. These engines had a 4.625 bore.... Gene
caseman-d
02-05-2007 20:39:26
 Re: Difference between 930 lp and diesel engine in reply to Gene Dotson, 02-05-2007 04:10:19
Gene,
Thought they used different block when they went to the 930 diesel and kept the same gas 377 that was also used on the 600 and 900 lp tractors and the diesels. I was thinking that the heads from a 930 and a 900 diesel wouldn't interchange. Aslo did the 600 have the dist drive of the front of the engine like the D or did they have the dist drive located by the starter. Seen 2 tractors that looked like 600's, but the dist drive was located in different spots. Can you assst me on this.
caseman-d
Gene Dotson
02-06-2007 04:28:57
 Re: Difference between 930 lp and diesel engine in reply to caseman-d, 02-05-2007 20:39:26
Caseman
Not sure if the diesel 930 was a different castine. The 1030 and 830 used the wide deck block with a wider head bolt pattern. The 730/930 use the same head gasket for gas and diesel, so I believe they were the narrow block casting. All of the "70 series used the wide deck block. Most internal parts parts will interchange.
There may be some errors here and welcome correction by anyone who has more information than I... Gene
hunter1
02-05-2007 04:02:16
Cast Iron Pistons in the diesel.
Aluminum Pistons in the Propane.
Motorken
02-04-2007 20:49:25
I have a Case 900 LP and it"s my understanding that the 377 in the lp and diesel were same casting number for the blockin those years...they essentially bored this block with same crank to get the 401 for the 930 series, yet apparently stuck with the 377 for the smaller production LP version??? Maybe to use up old stock??? Maybe because the propane engine coul put out a little more power than the diesel??? Anyway they added a longer stroke for the 1030 series with the same pistons as the 401.
I"ve been told you can bore the 377 and use the 1030 stuff in there for a cheap cheater that looks stock on the outside...not sure about heads or manifold differences...check the part #"s...
