Loader Valve For DB 990
rdandersom1
02-03-2007 13:07:51
I am trying to change the loader control on my mother"s 990 selectamatic from control by the 3 point hitch through a diverter valve to it"s own spool valve.My uncle had a Massey that took the hydraulic supply from one side of the remote valve, through a seperate valve for the loader and bucket, then dumped the oil back into the top of the transmission case.I could also supply the valve through the remote coupler and return through the other remote.I suppose I could also get supply from the diverter valve to the loader valve then back into the transmission case, but that ties up the 3 point hitch. I am not sure which is the better plan.I am changing from trip bucket to hydraulic so I need to change to the loader having its own valve. I never really liked the loader controlled through the hitch valve anyway. Any suggestions or advise would be appreciated.
richard in nz
02-03-2007 14:37:16
 Re: Loader Valve For DB 990 in reply to rdandersom1, 02-03-2007 13:07:51
A proper remote kit is (was) available for the tractor but was very expensive, the valves were made by cessna a wreckers yard may have some. You can take a "live" hydraulic feed by fitting a take off plate instead of the cast cover plate to the rear of your lift quadrant lever (I have made them in the past) a wreckers yard may have one. This will supply a feed for a set of aftermarket valves that can be mounted on the loader frame and controlled by morse cable. the return oil will go back into the other port of the plate to supply the selectamatic valve.When we were fitting loaders to these tractors a supply was taken from the 4 way selector valve on the left side to a set of Kontak spool valves mounted on the David Brown loader, the return oil going back to the trans lube line. The selectamatic valve was put into TCU/EXT (blue sector) and the quadrant lever cliped back into select to supply the remote valves but as you rightly say this islolates the 3 point, but this didnot really matter as most users dangled a geat lump of concrete on the back to keep the thing down untill of course the front axle had enough then another trip to a wreckers to get one from a 1200!
Davebr
02-03-2007 13:28:42
Try Emlmer at this address.
[email protected]
