case 430 vs D15 ac
Mike Schwartz
02-03-2007 10:29:14
Hello I was looking for some advise from anyone who may be familiar with these tractors. I have a 430 but looked at a D15 and wondered which may be the better tractor for me, can't justify both right now! The 430 is diesel, triple range,eagle hitch,power steering wfe. The Allis chalmers d15 is gas, wfe,snap coupler hitch, and has a loader. How do the tractor compare in the field, such as raking hay or pulling a pto baler? Any pros or cons as a utility tractor? Thanks for your help, MikeS.
dwag
02-05-2007 10:33:43
 Re: case 430 vs D15 ac in reply to Mike Schwartz, 02-03-2007 10:29:14
Most D14\15"s jump out of 3rd gear, which is really $$$$ to fix plus NLA on a lot of trans parts.
JRT
02-03-2007 20:15:43
Keep your 430. Those little tractors are hard to beat. That D 15 will burn 3 times as much gas as that 430 burns diesel fuel. They will go forever on a tank of fuel.
C. Amick
02-03-2007 16:47:48
How many cubic inches is the D15 engine? Some the those AC's have large engines, that's why they are good pullers, but that's also why they burn a lot of gas.
charley hellickson
02-03-2007 22:44:54
 Re: case 430 vs D15 ac in reply to C. Amick, 02-03-2007 16:47:48
Hi. Early D15 is the same as D14,148 cu. in., same power as Case 300-430 gas. Later D15 was upped to 165 cu.in. AC doesn't have live hydraulic like Case, push down foot clutch and hydraulic stops. Only way to get live is put hand clutch in neutral. Ac is also high preasure. AC is snap-coupler unless you put 3PT conversion on it. I like Eagle Hitch better. AC is good tractor, I lke Case better. That 430 has the Case 188 Diesel, can't beat it. More cubes. Hope this helps. Charley.
INCase
02-05-2007 07:01:04
 Re: case 430 vs D15 ac in reply to charley hellickson, 02-03-2007 22:44:54
They are very similar tractors in HP and size. The AC would be a bit heavier and a bit more power. The later D15"s had live PTO and Hyd. If it has the snap coupler it probably does not. I think the AC may be a bit easier to get parts for. More of them (common engine parts) and AGCO is (or at least was) better known for parts. (although I"d check for parts for an AC diesel before buying one) Unless you have steep grades both should run a "small" square baler with wagon all day. The smaller round balers need a Min of 45HP and 2 sets of good 2 way hydraulics (neither would work well for those) The snap-coupler hitch was an ok idea to get around the pattents in the 40"s but never better than regular 3pt or the Case eagle system. You must convert the snap coupler to use anything non-AC for lift implements. If you"d like an AC tractor I"d look at a Series4 D17.
