Flywheel Ring Gear
Jerry /TN
02-03-2007 08:51:40
Anybody have any idea where I may find a new starter/flywheel ring gear for a '47 Case VA?
mj
02-03-2007 13:19:44
 Re: Flywheel Ring Gear in reply to Jerry /TN, 02-03-2007 08:51:40
Not new but..... ?
Paul f
02-03-2007 12:17:46
Try your Case dealer...got one last year from him
wilson
02-03-2007 10:21:12
go to your local checker auto or any auto which has a PIONEER caralog. Most checkers do not ever know they have it!! take measurments or your old ring gear . It will run less than 40.00 bucks. If you have a problem getting it post back and I can help you.
CENTAUR
02-03-2007 09:08:27
I do not know, if we had the inside diameter and outside and number of teeth if we might be able to help.Do you still have the old one?You did not tell whats wrong with the one you have.If they are worn every 90 degrees,you can rotate the old ring gear 90 degrees,CENTAUR
