Case 1070/1090 Powershift
Lamont
02-02-2007 06:31:21
Uncle has a Case 1090 powershift that he is having shifting problems with. This is the 1090 that is the same as a 1070, only heavier built. I believe the trans is the same as 1070. The problem is not that bad. It is just awfully hard to shift from one range to the next. Once you get it in the range you want, it shifts through the gears great. What could this be?
c hess
02-02-2007 09:16:59
 Re: Case 1070/1090 Powershift in reply to Lamont, 02-02-2007 06:31:21
Could be from cold weather-Dont know where you live. You are both aware to idle an shift in that split second when engine labors when you push in clutch pedal an output momentarrly stops .
