2290 hydraulics
Jared Castle
02-01-2007 11:57:11
Here is the problem I have no hydraulics or three point unless I push in the clutch and dead head a remote (this only happened after I replaced the oil distributor hub before I couldn�t get anything) then I will have plenty of pressure until I shut off the tractor then I have to do it all over again I have read allot of the posts here and replaced the oil distributor hub and put all new seals in the clutch carrier new o rings anywhere I thought new should be we looked for cracks in the clutch carrier and even replaced it and it still don�t work right the shifting is all good all the gears are there and seems to have plenty of power .
430WLPG
02-02-2007 16:02:49
 Re: 2290 hydraulics in reply to Jared Castle, 02-01-2007 11:57:11
I agree with Eagle Doc, those little orings are bad about going away and when they are gone you can't build signal pressure to turn the pump ON
case trader
02-02-2007 04:32:36
i can feel your pain from hear an you have probably done all this, check charge press. at sending unit,pull filters make sure the rubber washer is not trying to suck into manifold,i've had trouble with the bypass at filter an regulator valve behind manifold opposite filter
case trader
02-01-2007 17:31:57
probably the first thing i would do is put on a compesater valve on th side of hyd pump i'v had trouble there if press. is slow or you have to work levers or clutch.
Jared Castle
02-01-2007 19:05:44
 Re: 2290 hydraulics in reply to case trader, 02-01-2007 17:31:57
I have already replaced the hyd pump and compensater valve I have been through the shop manual a dozen times I could write a book on what I have done to this tractor I have had it split three times and every where I have been someone has been there before me I have found nickels as shims and black and blue silicon everywhere any other Ideas anything will be appreciated.
c hess
02-02-2007 09:35:01
 Re: 2290 hydraulics in reply to Jared Castle, 02-01-2007 19:05:44
My feeling is some where there is some shim- nickels or silicone in your hyd system messing you up. Keep diging an cleaning till you find it.
Eagle Doc
02-02-2007 03:55:23
Have you worked on the hydraulic valve? Each section has a primary and a secondary shuttle. After the valve assembly is taken off the tractor you can get to the primary shuttles on the back side. Clean them and the replace the O-rings. The secondary shuttle requires the detent housing to be removed. If you take the detents apart, be careful not to lose any of the detent balls.
Jared castle
02-23-2007 15:19:29
 Re: 2290 hydraulics in reply to Eagle Doc, 02-02-2007 03:55:23
I have finally got a chance to look at the tractor again and looked all over in the book and cant find what you are calling a hydraulic vale could you be a little more specific I appreciate all of your help thanks again
