combine engine
Steve Sorensen
01-31-2007 15:12:39
I have ran across a in line four cylinder air cooled engine off case combine. Was this engine built by Case or somebody else? How old would this engine be? Thank's, Steve.
Jerry W
01-31-2007 20:35:30
 Re: combine engine in reply to Steve Sorensen, 01-31-2007 15:12:39
If it has a belt driven governor then it could be A188G or A201G. 188 and 210 cubic inch respectively. These are Case made engines. These were on at least some of the 600 series combines.
Jerry
Jim B.
02-01-2007 11:20:22
 Re: combine engine in reply to Jerry W, 01-31-2007 20:35:30
Opps, My mistake, there is no 210 or 201... that version is actually a 207... Water Cooled
Jim B.
02-01-2007 10:52:16
The 188 & 201 were/are water cooled.
Case at my place
01-31-2007 20:08:00
The Case A-125 was a VAC tractor motor with air cooled heads.
Case used it on various combines, swathers and balers through the years. 1957 they were an option on the 140 and 160 balers. The 840 Swather used it as standard equipment and was optional on the later 850. The first combine I know of that used it was the Model 75 in 1955, the Model 77 in 1957, and the Model 80 in 1960.
By the mid 60s, everything was pretty much pto drive.
