Case 400 questions for John Saeli
Keith 0301
01-29-2007 19:33:04
John - I just looked at a Case 401 today. It's a diesel, wide front end, runs good and the sheet metal is good. It's a 1957. Would this be considered a Super Diesel? It needs a steering wheel, radiator, seat, and fenders. Do you have these parts? The owner wants $1500 for the tractor with a real nice 6' brush hog. Is this a good price? The serial # is 80803...
Scott KY
01-30-2007 18:53:33
 Re: Case 400 questions for John Saeli in reply to Keith 0301, 01-29-2007 19:33:04
Keith, I've got 2 401's. Great tractors. The only downside is the gearshift takes some getting used to. The gears and the 2 ranges are on the same lever. They are a good strong heavy tractor. I don't think you will be disappointed.
John Saeli
01-30-2007 05:10:54
Hey Keith: Grab the tractor & Bush Hog now!! Ask questions later. Seriously, sounds like a fair price. Steering wheel & fenders are no problem. Radiators can be repaired. Might have to advertise for a seat. Good Luck!!
Keith 0301
01-29-2007 20:58:54
This tractor says 401 on the tag. What"s the difference between a 400 and a 402?
Doc Larry
01-30-2007 16:41:21
 Re: Case 400 questions for John Saeli in reply to Keith 0301, 01-29-2007 20:58:54
The 400 is the "Standard Tractor" with fixed width axles. The 402 is the Orchard, and the 403 is the High Clearance. The 401 is the General Purpose with adjustable front and rear axles but has other front axle options. The 401 is a kick butt old tractor in my opinion. But I"m biased, I have one and still use it.
Larry
Keith 0301
01-30-2007 18:33:04
 Re: Case 400 questions for John Saeli in reply to Doc Larry, 01-30-2007 16:41:21
Larry - what are the weak points and the strong points of the 400? Is yours a gas or diesel?
Doc Larry
01-30-2007 20:11:54
 Re: Case 400 questions for John Saeli in reply to Keith 0301, 01-30-2007 18:33:04
third party image
Mine's a diesel.
Well, I'll do the bad first. On the 3-point (Eagle hitch), the top link works best off the mount that goes over the PTO shaft, but that mount is almost always gone. When the top link is on the top mount, implements don't really work all that well, and the top link hits the hydraulic lever linkage and bends it. Not a great design to put the primary 3-point mount over the PTO, in my opinion. Let's see, the brakes have no outlet for the inevitable dust so if the machine is left outside much the brakes end up a rusty mess because the powder holds moisture in. So mine lives inside the shop. The cat likes the seat so everyone's happy. If you have a diesel with the original three filter setup dirt in the initial screen filter will shut you down on a regular basis if you don't have a nice clean fuel tank.
Good side is almost everything else. As far as engine, transmission, axles, it's a horse as far as I can tell. Pulls great, lots of torque, well balanced. Most parts are surprisingly easy to find if you can find a dealer who gives a rat's "censored". My, this site is getting prissy! Anyway, the 400's my favorite tractor. I'll buy another if I find one half as nice as this. I moved her with us up to Montana last summer as per photo.
C. Amick
01-31-2007 10:06:26
 Re: Case 400 questions for John Saeli in reply to Doc Larry, 01-30-2007 20:11:54
Very nice tractor. Perhaps someday I'll run across one for sale that is not too far from home.
Jim from Calif
01-29-2007 20:46:04
The 1st Super was Serial 8106131. Your Case 400 serial number is from a 1955
