530 serial number
ctfarmer
01-28-2007 13:47:52
I am rebuilding the 188 diesel engine in my 530 and need the serial number to order the right pistons and sleeves (there are 2 different sets available) The serial tag on the tractor is missing, but the ones on the loader and hoe are as follows 4063521, 4059521. Is the serial number stamped anywhere else. I found a nimber 3 9 61 on the right side of the trans case, is that the prod. date? Any help would be appreciated
Tom (Ks)
01-29-2007 17:23:20
 Re: 530 serial number in reply to ctfarmer, 01-28-2007 13:47:52
I ran into a problem when I overhauled my 530 several years ago, the serial number break was wrong in the parts books. Mine was supposed to be narrow flange sleeves but was a wide flange block. The last guy that overhauled it put the wrong sleeves in it. You may have to tear it down first to find out what you have. My engine was dated 3-68 on the block after I removed the power steering pump and found it.
K Woodrum
01-29-2007 10:56:02
You can take the sleeve out of the engine and they can check the size of the sleeve to get the correct ones
Jim from Calif
01-28-2007 17:30:25
You can narrow down the Serial a bit based on the configuration. 1. What is the serial number on the engine.
2. Is it an eagle hitch, or draft-o-matic?
3. Does it have a dash gauge cluster or does it have individual gauges? 4. The very early models had disk-type brakes, vs the band brakes on the later models. 5. There were at least 3 different power steering setups .
6. With this data, people on this site can narrow it down to a serial range.
