Winterizing question
Mathias NY
01-26-2007 08:00:47
I am plowing snow with a Case D and it seems to be running richer than it does in warmer weather.
Does the oil in the air cleaner need to be thinned out for winter conditions?
I know the engine and trans oil need to be changed, but never gave any though to the air cleaner.
Mathias NY
01-27-2007 05:46:43
 Re: Winterizing question in reply to Mathias NY, 01-26-2007 08:00:47
Thanks for the tips.
I decided to thin out the oil-bath with a little kerosene. Seems to work better now. In spring when I change the other fluids back to heavier weights, I'll change the filter oil too.
Doc Larry
01-27-2007 05:27:25
You should use lighter oil in the winter. Or use multi-vicosity oil. If you get very much blowing snow into the air intake, you can end up with water in the bottom of the oil bath that can eventually rust out the pan bottom if you are lax about changing the air cleaner oil.....
Larry
BCnT
01-26-2007 08:13:01
small self propelled snow blowers dont have a air filter at all...i'd dump the oil completely if all youre gonna do is push snow...dont forget to refill before spring tho
