Case 801B
Horseshoer
01-25-2007 21:02:54
I have a 801b diesel Caseomatic. When pulling in what I call low range it slips. When I flip the lever to high it does not slip. I have not had the tractor long. Wich range is direct drive and is it proper to pull in direct drive. I plan to use it for plowing and grading with a box blade. The clutch pressure is good. I have not changed the filters. Can you tell me if this is a major problem and the location of the trans filters and the oil type. Thanks for your help
BobV
01-26-2007 14:12:14
 Re: Case 801B in reply to Horseshoer, 01-25-2007 21:02:54
This also applies to Gene, I have a 400B which is smaller than your 801B but Case O Matic is the same, Gene you did a good explanation of the Case O Matic operation, I can add the type of fluid also will help the torq converter operate better, use Dextron III it cleans and helps to stop the gear grinding when you start up. Case O Matic was ment to be used in hard pulling conditions, us it that way and you have a very strong puller, enjoy!
Gene Dotson
01-26-2007 02:58:35
Your system sounds normal
Case-O-Matic drive is a torque converter mounted ahead of the transmission. It has an in internal clutch that can be engaged to stop all slippage from the converter. Low range does not change gear ratios, only unlocks the converter clutch to allow the engine to run at a higher speed and not stall. The tractor movement is always started in low Case which allows the converter to drive like starting out in your car or truck with automatic transmission. The tractor can sit at idle in low Case and not move until the throttle is advanced. The faster the engine runs, the more power is transmitted through the converter, therefore less slippage. The tractor should not be used in low Case for long periods under a heavy load or the oil will get hot. Always idle the engine before changing gears and engage the foot clutch at idle and use the converter to get moving, then shift to direct drive. Inching is done with the clutch engaged and controlling movement with the foot throttle and brake. Works nice and smooth and reduces wear on the clutch and hydraulics. I have often left the tractor in gear and idling while I got off to pick up rocks or adjust the equipment.
Kinda long winded, but the Case-O-Matic is a great system when you understand it and use it as it was designed... Gene
