VAC-14 wide front oil pan removal update
Mike Noonan
01-24-2007 19:09:56
I have finished removing the oil pan, renewing & replacing the oil pump and the oil pan. I did not have to pull the whole front end. I only had to slide the front end away from the engine about 3/4". To do this I removed the 4 bolts of the radius rod pivot bracket at the back of the wishbone. Also removing the steering support bracket at the back of the motor. I then replaced the top 2 bolts holding the front support to the engine with longer bolts and then I just slid the front away about 3/4". This gave me enough room to get the front of the pan down clear of the oil pump. I did use blocking under the transmission and a cherry picker to hold up the engine. Of coarse I had to also remove the hood, grill and radiator. Thanks to the fellow that responded to my question about this.
