neg or postive grd on battey
homerd
01-24-2007 17:51:50
with a 52 case vas if you use a 12 volt battery, 6 volt starter and a 6 volt generator which is the ground on the battery pos. or neg.? if it was 6 volt all the way the grd would be pos. thanks
Steve-MN
01-26-2007 16:34:59
 Re: neg or postive grd on battey in reply to homerd, 01-24-2007 17:51:50
Hi Homerd,
Another note is to be careful of a 12 volt battery. It slams the bendix into the flywheel pretty darn hard. Good chance to bust stuff that is hard to fix. 6 volt batteries work just as well as 12v if everything is tuned up. I got an LA & the 6 volt works fine(well, not at 30 below). Cheaper battery too.
Good luck,
Steve
Paul f
01-27-2007 06:00:15
 Re: neg or postive grd on battey in reply to Steve-MN, 01-26-2007 16:34:59
I have to agree with Steve about staying 6 volt. I put new 1 ga wires on my VAC cleaned up all the connections and she cranks almost as fast as a modern vehicle.
Paul f
01-25-2007 06:25:20
VA series are all Positive Ground...unless someone changed it over the years. First look at battery does + terminal wire run to ground?? Look at your coil is the wire from the + terminal the one that goes to the distributor??? That would be positive ground wiring.
One more thing..12 volt battery and 6 volt generator = dead battery....
JGarner
01-25-2007 05:40:53
Homerd, take a look at the "Pos or neg grd?" post below. Voltage doesn't have anything to do with ground plus I am not sure if the VAC was pos ground. If the statement below is true, and I believe it is, your VAC should be negative ground I think all of these VA series tractors were made in Racine.
Gene Dotson
01-25-2007 14:17:59
 Re: neg or postive grd on battey in reply to JGarner, 01-25-2007 05:40:53
VA series tractors were made in Rock Island with positive ground.. D, S and L series were made in Racine... Gene
All bets are off when installing a 12 volt system. Most alternators have negative ground systems. Generators can charge either way, depending on the polarity of the regulator and how it is polarized... Gene
JGarner
01-29-2007 07:08:12
 Re: neg or postive grd on battey in reply to Gene Dotson, 01-25-2007 14:17:59
Gene, I had thought all Flambeau red tractors were made in Racine. Didn"t know VA"s were made in Rock Island. I thought Rock Island didn"t come into play until 53/54 onward.Thanks for clarification.
