830 CK gas starting problems
Robert Wullschl
01-23-2007 20:02:58
I have an 830 comfort king gasburner. Lately, I have been unable to get it started and keep running. It will run for about 2 seconds then die. I have replaced points, condenser, coil, cleaned carburetor. Any help would be greatly appreciated.
shawnspeed3
01-24-2007 08:30:14
 Re: 830 CK gas starting problems in reply to Robert Wullschleger, 01-23-2007 20:02:58
on the fuel tank support/firewall right behind the engine , it's about 1/2" square 1 1/2" long outside should look like raw porcelen, it knocks the voltage to the points down to 6 volts to make them last longer...I removed mine 6 yrs ago and am still on the same points with 12 v..... dosen't seem to have affected much yet...Shawn
Robert Wullschleger
01-24-2007 16:17:25
 Re: 830 CK gas starting problems in reply to shawnspeed3, 01-24-2007 08:30:14
Thanks for the help. We had the same thing happen on another '30 series tractor probably 20 years ago. I had forgotten about that. I will try bypassing it and see what happens. Thanks again.
shawnspeed3
01-24-2007 04:17:33
Mine did the same thing, check the ballest resistor (or remove it) , if your tractor quits as soon as you let off the start position on the key switch, thats more than likely your problem. there is also a screen up in the fuel tank that can plug...I usualy take out a plug in the fuel sediment bowl/petcock and blow up into the tank...works for a little while. Hope this helps Shawn
Robert Wullschleger
01-24-2007 06:54:05
 Re: 830 CK gas starting problems in reply to shawnspeed3, 01-24-2007 04:17:33
Thanks. Where is the ballast resistor located? That sounds like what is going on for sure.
