Wiring Harness,LA
Ande
01-23-2007 16:21:14
Does anyone have a idea where to get a complete electrical wiring harness for a 1949 "LA"? Is there good and bad ones?Any info would be great
Ande
bleedcase
01-25-2007 09:18:28
 Re: Wiring Harness,LA in reply to Ande, 01-23-2007 16:21:14
The only place i would get a wiring harness is Through AGRISERVICES. I just got done restorein a 48 model la and i bought a complete wiring harness for it. 3 lights, gen, starter, gauges, and plus it looks original with cloth covered wires and everything. the guy makes them when you order them. their a lil expensive but they look tremendous. i can get you the number for them if you are interested.hope to hear from you. trust me you will like them
Ande
01-25-2007 11:58:04
 Re: Wiring Harness,LA in reply to bleedcase, 01-25-2007 09:18:28
Hello BleedCase,yes do you have a link? If not I will do a search.Thank you Ande
Walt Davies
01-25-2007 06:48:12
$90 is lot of money for a simple wiring harness like the LA has. They want $40 for the Generator harness that's two very short wires from the Generator to the Regulator on top of it and one wire from the Gen to the amp gage and one from there to the battery.
the lights are even less. I say make your own and save a bundle.
Walt
Engineer20
01-24-2007 07:07:20
Found it.....
Ande
01-24-2007 09:40:40
 Re: Wiring Harness,LA in reply to Engineer20, 01-24-2007 07:07:20
Engineer20,thanks for the information,sure looks like a good place to do business.Have you used them before?
Ande
Engineer20
01-24-2007 15:55:08
 Re: Wiring Harness,LA in reply to Ande, 01-24-2007 09:40:40
I ordered a harness for my LA thru them. It looks real nice. But I have not installed it yet since I'm not that far along. If you have lights be sure to tell them where exactly they are located.
Engineer20
01-24-2007 07:05:46
There is a company that makes them. I'm at work and don't have the name of the place. Try doing a google search.
JGarner
01-24-2007 05:54:24
Do you have a wiring diagram for the LA? I found a diagram and wire color code for my 630 on the Case IH parts search site. There is enough of my old one left on the tractor that it will be good for lengths. NAPA sells all of the items needed to assemble a look alike, historically correct, harness from scratch, including the woven wire loom material in various sizes.
If you have anything left of the old one for length reference and any kind of DIY skills you can assmble your own from new materials.
Ande
01-25-2007 05:13:08
 Re: Wiring Harness,LA in reply to JGarner, 01-24-2007 05:54:24
Hi JGarner,you have a point,guess it will depend if I will take the time,and as you said have enough of the original left to make one from.Thanks for your thoughts Ande
