hitch
stanleypavloski
01-23-2007 10:25:05
I have a case 411 with eagle hitch, can i convert to 3pt, and where do i getparts to do so.
Stuart Hale
01-24-2007 15:53:16
 Re: hitch in reply to stanleypavloski, 01-23-2007 10:25:05
Hi,
I recently bought a Case 630 with eagle hitch for my brother and I to use. This is my first tractor with a 3 point hitch and only my second tractor, so I hae a lot to learn. I bought a bush hog for it and discovered the two lower arms wouldn't latch on the pins. The pins have a raised boss on the outside the the hitch hits. They guy I bought the tractor from also delivered the bushhog and we taked about it for quit a while and he suggested switching to a Ford style three point (the loose one). I can get the arms at Tractor Supply, but I'm not going to. I'm going to take the pins off and take them to work and turn the emboss down till I can get my arms in there. Then all I need is a set of top link pins and to do some adjusting on the bush hog. I like the eagle hitch and think I'll stick with it. It worked 40 years ago, so it should still work today.
Stuart
JGarner
01-24-2007 06:04:13
You have the best 3 pt hitch system ever built. Why would anyone want to change over to a sub standard Ford design? Our eagle hitches hooked up to every 3 pt tool we had and most others can be adapted by turning lift studs around.
mj
01-24-2007 10:46:50
 Re: hitch in reply to JGarner, 01-24-2007 06:04:13
third party image
Ya know, I've got to disagree. I'm even more of a non-Ford man than I am a Case man BUT in this instance I've got to say that the Ferguson System is way out in front of the Eagle when it comes to convienience and adaptability. Yeah, you can hook up about any brand implement to an Eagle by moving the draft pins around, loosening the draft arm brackets for a wider grip range, etc. but why bother? AND no matter what you do to the Eagle you can't get an implement to sway side-to-side like you can with the Ferguson. Having no sway just doesn't work on some implements like toolbar markers (shown) for furrow irrigated ground. You can get sway or not using chains or blocks on the Ferguson pattern hitch but you have no choice on the Eagle. I've got 3 VAC adj. wf tractors that I use: one has a Ferguson type 3-
point hi-pressure hitch and the other 2 are Eagles. I often use the home-built 3-pt. just because I don't want to take the time to reset one of the Eagles. Since the Eagle pump and rockshaft are so excellent I am going to convert the draft arms and links to the Ferguson type on at least one of the 2 others. By the way, I've had to re-weld the tube where the claw goes into the end of the Eagles' tubular draft arm due to stress cracking but my homemade arms are as good as they were when I made them 25 years ago. The Case Eagle hitch along with the A-C hitch were both good but the Ferguson has become universal.
JGarner
01-25-2007 06:01:46
 Re: hitch in reply to mj, 01-24-2007 10:46:50
I guess we have to agree to disagree. We had 2 Fords, 2 Cases, a JD R and D2 Cat on our ranch in Colorado. Rigid eagle hitch beats the floppy old Ferguson/Ford system any day in my book. You don't have to get off the tctor and wrestle with pulling pins and jerking the implement around or having two people to hook up and when using implements like a post hole digger and back blade the rigid all the time arms beat the heck out of having to asemble and disassemble stiffeners when you don't need the float. Make mine eagle anyday!! The Ford was good for mowing, raking and front end loader but that was about all.
mj
01-25-2007 21:10:31
 Re: hitch in reply to JGarner, 01-25-2007 06:01:46
third party image
Yeah, I agree that the execution of the system on the Fords, etc. left a lot to be desired BUT the basic concept of the 3-point was Harry Fergusons' idea and is very well thought out. I've had Fords and you are exactly right on the sway-bar issue; that's why I rigged my Case up with sway chains mounted outboard of the draft arms rather than to the inside. Leave them a bit loose and you don't have to fiddle with them if the implement is even close to current specs. I also agree that hookups with proprietary implements is a snap with the Eagle hitch but then so it was with A-C's 'Snap Coupler' setup and their implements. I still need the sway for marking 'corrugates' though and that the Eagle will not do. So, I am pleased to agree to disagree with you. :-)
stanley pavloski
01-24-2007 07:37:25
I am having trouble with the centerlink hookuo on my 411, it wont let the 3bottom plow to level off. ii i adjust it so all 3 shares plow it wont let me lift it to clear the ground at the end of the field ,it drags
Paul f
01-24-2007 08:31:46
 Re: hitch in reply to stanley pavloski, 01-24-2007 07:37:25
Stan: I hope somebody with a 411 chimes in. On the older DCs there are two top link attachment points. One is above the PTO shaft. The other is on a plate you bolt over the PTO shaft when not in use. That lower point will give you higher lift. I had a similar problem with my back blade... Using the top point it wouldn't lift high enough. I had a PTO cover plate with mounting ears fabricated an problem solved. (Original plates are hard/expensive to find.) To me sounds like just changing out your draft arms for Ferguson ball sockets won't solve your problem. For brush hogs and such that need teh PTO you can try raising the mast (attachment point) on the implement itself...don't think that would be as easy with your plows.
Paul f
01-23-2007 13:09:47
Eagle hitches work pretty well. I have a 3 pt finish mower, back blade, york rake, and borrowed brush hog...all work just fine on my DC and VAC both with Eagle Hitch...Even saw some adapters in the Northern Tool catalog that convert the ball ends on a 3 pt to a pair of latches that look alot like a Eagle hitch
