Oil Getting Into Exhaust 1990 case 585 Tractor
diesel weasel
01-21-2007 14:37:23
We Have A 1990 Case 585 Tractor Getting Oil In Exhaust. Last Year The Head Was Redone. Exhaust And Intake Valve Seals Were Replaced And Valve Guides Were Knurled Problem Solved. This Year Same Problem. Compression Is OK. Rings Seem To Hold oil In Cylinders For Hours On End Engine Runs Really Nice. It Has floating Seals On Exhaust Valves. I Never Had Heard Of Them All The Ones I Have Ever Installed Fit Tight Over The Valve Guide Bosses. Could This Be The Problem
dwag
01-22-2007 10:32:05
 Re: Oil Getting Into Exhaust 1990 case 585 Tractor in reply to diesel weasel, 01-21-2007 14:37:23
What looks like oil in ex manifold could be unburned fuel, which is common on diesels that are not worked hard. Try working tractor under load for a while, eng should dry up. Hotter thermostats will help.
dwag
01-22-2007 10:31:28
