Low Profile 930 Transmission Oil
Bobl1958
01-20-2007 16:11:41
I would appreciate it if someone could shed some light on what transmision fluid to use in a 1962 propane 930. I have the original owners manual which says to use TCH. I have bought some generic trans/hyd oil which says it is compatible with Case TCH. It is a 10/20 wt. Is the trans oil this thin? My neighbor, who ran Cases all his life says he always used 80/90wt. I guess my question is does this tractor actually take a thin oil? It"s a 6 speed if it makes any difference. Thanks-Bob
Jimmie D. Phelps
01-24-2007 21:40:35
 Re: Low Profile 930 Transmission Oil in reply to Bobl1958, 01-20-2007 16:11:41
I have a 900 LP and a 1966 CK six speed. I use 80/90 in both. My 930 called for TCH which was in it when I bought it in 1971 with 2000 hrs on it. I changed than to 80/90 with a gallon of wynn's charge. I now have 8400hrs and have never changed oil again and have not had a min's trouble with it.
drbunson
01-21-2007 21:33:29
We have a Diesel 930 with an 8 speed. On ours the hydro fluid resivior is the tranny. We use Mobil Fluid insted of TCH, it's a bit cheaper. The fact that your book says use TCH oil, I would suspect your tranny to be set up the same. I have heard of people running a thicker oil if thier pump or oil seals were wore or leaking, but thats only a temp fix. Hope that helps.
Bob
Camboted
01-20-2007 18:58:54
What climate are you in? In Cambodia we run 140W in all our chain drives, but we are 90 to 110 degrees. If you are in a place where it gets cold consider a heavy multi grade like 80w-140 or something like that?? I think the thiner oil was meant for the eight speed gear drives, but I could be wrong. Plain old 90W is standard.
