Autolite distrutor
Gauger
01-20-2007 10:13:36
I am helping a friend with his VAC. He said he was getting alot of oil leaking around the distributor housing. I looked at the manual and it mentions an o-ring. There is none there and I have looked at a second VAC distributor and it too has no o-ring. There is no groove in the housing for an o-ring. There is a odd looking washer between the bevel gear and bottom of the housing. Could an o-ring go in there??
Bob
01-20-2007 10:50:28
 Re: Autolite distrutor in reply to Gauger, 01-20-2007 10:13:36
I used to own a VA, and it seems to me there was a cork ring installed around the "neck" of the distributor, between the hold-down bracket and the block.
You could clean it up real good, and put a small amount of silicone sealant around the area, setting the timing before the silicone hardens.
The distributor could still be easily removed, if needed, at a later time, as the silicone will easily let go.
