Case 42 Loader Working Intermittetnly
Ed in Ohio
01-20-2007 10:02:08
I have a W3 with a Model 42 loader and backhoe. The hoe works fine, maybe a little weak on power but functions OK. The loader works intermitently.
I was moving some gravel and it would work OK when the tractor was level, but as soon as I ran up the pile a little and the tractor was at a slight angle it becomes very slow. It also became very weak when I would try to pull the top of the pile towards me. It was like it was stuck in float. The contol lever normally has a definate pop when it goes to float but whenever there is any pressure up on the bucket the lever goes easily into float with no pop. I am unable to get down pressure at all and the bucket would just ride over the top of the gravel pile. I hope I explained this well enough. Any advise on what could be causing this problem is appreciated.
