hey Thad or? 1896 question
case trader
01-19-2007 18:41:41
just got this tractor an clutch seems to drag hard to get out of gear then wants to grind going in clutch seems to release ok but has a slight drag linkage looks ok when the bottom switch disingages if you have press. on the lever it will release for a split second like a valve is leaking? warped disc? have not checked any press. yet. does not slip in any gear.any ideas. (we have power but it is so slick a cow can't walk)
hunit
01-20-2007 09:37:15
 Re: hey Thad or? 1896 question in reply to case trader, 01-19-2007 18:41:41
ours is like that too when it cold let it warm up some more b4 moving... dont push clutch in when starting either i find that helps some too
