Leaking Rear Axle Seal-VAI
Kestrel in CT
01-18-2007 12:56:39
third party image
It seems after hauling some heavy loads this winter my rear axle seal had seen enough and is now leaking enough to reach the floor.
I checked the archives and my service manual but didn't see if it is best or nescessary to first remove the axles in order to get the old seal out. Any ideas out there ? Can they be extracted easily with the axles left in ?
I see Case recommends an oil seal driver to drive the new one on. I'm in new territory here.
Thanks guys.....
CENTAUR
01-18-2007 13:39:55
 Re: Leaking Rear Axle Seal-VAI in reply to Kestrel in CT , 01-18-2007 12:56:39
Once you get to see the seal I would drill or punch a hole to get a metal screw into it. These metal type screws are usually part of many slide hammers.You might be able to just screw one or two in and then put a vise grip or two and pull or pry.An ordinary piece of pipe that fits the seal will make a good driver.CENTAUR
Kestrel in CT
01-19-2007 05:41:29
 Re: Leaking Rear Axle Seal-VAI in reply to CENTAUR, 01-18-2007 13:39:55
Thanks Centaur. I'll start with that idea. These wheels probably haven't been off since the Carter administration, so the fun begins.
