loader for 1370
agman
01-18-2007 08:17:51
I need a loader for my 1370 tractor. There do not seem to be very many 80 and 85 loader which were designed for this tractor available. Any ideas on what of other brands will fit my 1370? Thanks.
Agman
Moline_guy
01-19-2007 11:04:43
 Re: loader for 1370 in reply to agman, 01-18-2007 08:17:51
Du-al manufacturing has made quick tach loaders for several years and now is called Woods-Dual out of Souix Falls, South Dakota and are available at many dealers in the northern plains. The model you would need for a 1370 is a model 3050(older) or 3150(newer). The only difference between these two numbers is the type of cylnders that were used. They also make a 3000 and 3100 quick tach but these were for narrow frame tractors like the 970 or 1070 Case so they would not work on the wide 1270 or 1370. I posted a picture of my 1955 oliver last week in the tractor photos with a 3000 Dual loader and looks just like the 3100 and 3150, if you have never seen this type of loader. When you go to tractor photos go to the oliver category and it should be in the first couple of albums. They are good loaders and go on and off in a few minutes with no jacks. Good luck with what ever kind you find.
John Saeli
01-18-2007 08:55:23
Back when the 1370's were built, Great Bend built the Case loaders. The Great Bend High Lift would be a nice unit on that 1370.
