information on vac tractor
will in texas
01-17-2007 16:21:32
i have bought a vac tractor that has 11.2x34 tires is this a standard tire size for the vac the serial number is vac4830012 any information will thanks dctom for the info.
Jerry W
01-17-2007 20:33:06
 Re: information on vac tractor in reply to will in texas, 01-17-2007 16:21:32
That was a standard size on the later VAC 13"s and I do not know how early they started the 34 inch rubber but typically you do not see it on tractors with less than 5570000 serial number. Tall rubber on early VAC is usually 32" and not 34". You can kind of tell the vintage of the cast star centers by whether or not the casting numbers are on the inside or the outside. Early tractors have the foundry marks on the outside. Later tractors also have a wider spread on the clamp bolts that pinch the star center to the axle. Jerry
Ron in Mich
01-17-2007 17:51:57
We have a 1951 VAC that also has 34 inch tires; not sure of the width. Ours has the Eagle hitch and works well with 3 point rear blade. Nice tractor!
Good luck with it.
will in texas
01-17-2007 19:14:40
 Re: information on vac tractor in reply to Ron in Mich, 01-17-2007 17:51:57
yes i just got it i already have two vac's 1947 it has a self made three point and a 1948 this makes three i also have a 1951 dc that has two point lift. all i have to do now is paint them the 1944 i have to get tires and unstuck the motor then paint. i have a 1942 bf cavery what i mean by that is avery frame with a vac case motor and torque tube and home mad coupling to make this all work it has a front end loader and a three point lift that i built my self. any way
