CASE SC cylinder pressure
Johannes
01-17-2007 14:48:43
Hello,
I had the head of my 1949 CASE SC rebuilt (ground, new valves and guides and so on). The pressure in all 4 cylinders is now 80 psi. Is this a proper pressure.
Thanks, Johannes
John Saeli
01-18-2007 05:32:44
 Re: CASE SC cylinder pressure in reply to Johannes, 01-17-2007 14:48:43
The fact that the pressures are even is good, but 80PSI is low. 100PSI all the way across would be good. The proper way to check compression is to remove all the plugs so engine will spin freely, make sure battery is up. Open throttle wide open so she gets maximum air. Good luck.
Johannes
01-18-2007 12:55:03
 Re: CASE SC cylinder pressure in reply to John Saeli, 01-18-2007 05:32:44
Thank you very much for your reply. Assuming that, when I did the pressure test, I took all the proper precautions and the pressure was still 80 psi, how can I improve the pressure in the cylinders?
Thanks again,
Johannes
John Saeli
01-18-2007 16:36:20
 Re: CASE SC cylinder pressure in reply to Johannes, 01-18-2007 12:55:03
Hey Johannes: I just shot an e-mail back at ya..
