Differential for case 1200
Don Dietrich
01-16-2007 03:25:11
I was wondering if anyone knows where I can get a differential unit for a case 1200 Its a rockwell axle model PS 154 HX 8 the gear ratio is 5:29. I know rockwell makes axles for trucks I was wondering if a unit out of a truck would interchange?
WBWi
01-18-2007 11:40:05
 Re: Differential for case 1200 in reply to Don Dietrich, 01-16-2007 03:25:11
1470's also used rockwell differntials, I know they use the same gear ratio and housings, but I'm not sure if it is a bolt on interchange
WBWi
01-18-2007 11:39:55
Jeff From WI.
01-16-2007 07:11:19
Hi Don, Look on e-bay. Just type in case 1200
John Saeli
01-16-2007 04:31:28
Hope you have better luck than I'm having. I'm looking for a Pinion Shaft for a 4690. They use an Eaton 16000 differential.
Elmer
01-16-2007 04:59:59
 Re: Differential for case 1200 in reply to John Saeli, 01-16-2007 04:31:28
Try these guys John
http://www.gcparts.com/
