DC parts needed.
Scott KY
01-13-2007 17:43:26
I need 2 male tie rod ends (the ones that attach to to arm on the wheel spindle)for an adjustable wide front. Someone has beat on mine with a hammer and damaged the threads that the plugs screw into. I need the plugs also.
idahodave
01-20-2007 10:15:10
 Re: DC parts needed. in reply to Scott KY, 01-13-2007 17:43:26
Mine were shot...plugs missing, one broke in half
Tried to find replacements with no luck.
Called John Saeli and he came up with a tie rod end from another tractor(a red one I think) that would fit into the middle tubes. It had a modern rod end on it and I had to drill out the ball and bolt the rod end in where it was. Also had to grind notches in the rod where the adjusting lock bolts go. Worked good, not too expensive. Mine is a working tractor so I didn't mind the loss of the case part too much.
