VAC light switch - anybody got a picture?
Glenn in Indian
01-13-2007 09:35:08
I'm still trying to get the charging system working properly on my VAC. I found a complete schematic in a prior post(thank you!)and now I've figured out that the light switch on mine is not the correct one. Does anybody have a picture of the light switch with the built-in resisitor? A NAPA part # would be helpful, too! I can get the tractor to charge, but it drains the battery when it sits overnight.
jal-SD
01-15-2007 08:23:36
 Re: VAC light switch - anybody got a picture? in reply to Glenn in Indiana, 01-13-2007 09:35:08
Believe it or not, you can get a switch that looks & works just like the original switch that Case used from your local JD dealer. Go to your nearest JD dealer and ask the parts guy to look up & order the switch for the older G, A & B series that used a cut-out on the generator. Bought one last spring from Ellifson Implement, Mitchell, SD, about $15, if I remember right. (I think that a JD's dealer supply network is much better for old stuff than either IH or Case.) Had to go to a friend's house to get a copy of the wiring diagram for an old A, wired my VAC up the same way & WALLA-it charges like a trooper & the lights work! I'm a red & flambeau red fan, but whatever color works to keep them running is great, as far as I'm concerned. (My $0.02 worth. jal-SD)
Walt Davies
01-14-2007 08:44:24
look on ebay for light switches case tractor John salie has them all the time on there.
Walt
Glenn in Indiana
01-13-2007 13:09:28
My email address is [email protected]
Thanks!
c hess
01-13-2007 12:00:18
Send me your e mail. I dont know how to send photo on forum but can srnd by e mail.
