babbit bearings
Jerry Thomas
01-12-2007 16:20:23
Hey whats it usualy cost to get the bearings repoured? Thinking of overhauling a DC if I can find a kit. JT
C. Amick
01-15-2007 09:48:56
 Re: babbit bearings in reply to Jerry Thomas, 01-12-2007 16:20:23
There is a guy who advertises in Antique Power Magazine that sells rebabbited rods for another tractor make. The price seemed reasonable. He may be able to do yours? If interested, email me and I will look up his phone number for you.
Camboted
01-13-2007 07:14:41
Jerry, we bore out the rods, machine in a notch, and build replaceable inserts. The problem is we need both the rod and the crank to do the job because each one is an individual fit. It really makes a nice smooth engine but, we'd have to have you ship the entire engine to us, and we are in Cambodia. LOL!
SHeiserman
01-13-2007 07:52:57
 Re: babbit bearings in reply to Camboted, 01-13-2007 07:14:41
I need to replace sleeves and the pistons in a DC, how much do you think it would cost here in the states to do the machining job you just described vs. having the babbit re-done (which I'm only assuming would have to be re-done)?
Camboted
01-13-2007 13:09:44
 Re: babbit bearings in reply to SHeiserman, 01-13-2007 07:52:57
My guess is that when you start paying $75.00 per hour for machine shop work, you'd be better off to re-pour the babbit. I doubt if your DC needs to have new babbit. Unless all the shims are gone, just remove them until you sense a little resistance to the rotation, bolt it tight and go to work.
Gene Dotson
01-13-2007 02:56:29
Jerry; The rods are very robust and seldom need repouring unless they have been damaged by lack of oil or contamination. There are shims between the rod and cap that can be removed to reduce bearing clearance. Don't tighten them too much. Need .0025" to .0045" clearance to live... Gene
wayne2
01-12-2007 19:34:46
Prices are like locations-different. call some machine shops.Had a Model A done in 65 so i'm really no help. Luck Wayne
