stockton hitch
Wheat Straw
01-11-2007 19:18:39
Took a little ride through "Case" country Wednesday (Northwest Ok) and saw a new toy. It was a variation of the stockton hitch i had never seen. I've only seen about six of them but yesterday was the first time i've seen the cadilac model of it. It was on a 43 vac awf tractor. The difference was that the live pump on the cam was on it and the valve body for the remote cylander on an eagle hitch vac was on it. A bracket is added to the bottom of the lift yoke that extends it down below the torque tube so a cylandor can be mounted under the belly. A hydro, cyln. is mounded underneath to the front of the rear end housing where the draw bar hinges and on the extension to the lift yoke. This then actuates the lift yoke from the bottom side instead of with the small cylinder on the left side of the tractor.This then works the lift bars that go down each side of the operator to the lift arms. Instead of the lift arm fastening directly to the lift yoke they have a slotted cast bracket that clamps onto the lift arm and then a bolt goes through the slot and onto the yoke thus allowing for float of the implement. Looks like a much better plan than the old one with the piston and piston guide that bolts onto the torque tube on the left side. Other than that it is identical to the one in the pamphlet that is form 5763 2500 6-49. Any of you guys ever seen one of these? It was a clean factory set up and the actuating lever had old abe cast in it.
This tractor also had a mag mounted on the hdro pump.
Wheat Straw
mj
01-11-2007 21:06:25
 Re: stockton hitch in reply to Wheat Straw, 01-11-2007 19:18:39
third party image
Like the one at the top? I've never seen one but a buddy farmed with one in Western Iowa 'back in the day' and he described it like the one you saw. I have a VAO with most (missing the yoke or 'wishbone') of the lower one on it.
Wheat Straw
01-12-2007 05:12:15
 Re: stockton hitch in reply to mj, 01-11-2007 21:06:25
mj, Just wondering, the controll valve for this item bolts onto the side of the torque tube to the right hand side. It's raining and cant get to my 47 to see if there is a place for it on the torque tube. Surely they didn't have to replace the torque tube too did they?
Wheat Straw
mj
01-12-2007 07:12:25
 Re: stockton hitch in reply to Wheat Straw, 01-12-2007 05:12:15
No, they didn't replace the torque tube. I thought I had a close-up of my VAO setup on line but I don't. I'll get some today and post them here this PM.
mj
01-12-2007 09:20:32
 Re: stockton hitch in reply to mj, 01-12-2007 07:12:25
third party image
Well, here's one picture of the bracket that mounts the valve and adapter to the torque tube. If you click on the link you can see more. Click an image to enlarge and view.
Wheat Straw
01-12-2007 04:47:47
MJ,
I was hoping someone had something like this breakdown you posted. I've got dad's old 46 vac here on the place that this pamphlet of mine came with but we never did have the hitch. Had seen a few of them and always wanted one. This one would have been a better unit than the ones I had seen.
Thanks for posting.
Wheat Straw
