VAC Carb
FM
01-11-2007 09:20:59
Went to push up feed this morning at work, and the VAC we use for that was way overfull of oil. It had a slight gas odor. Per bosses orders, I pushed up feed. It started and ran fine. It seems I've heard the float in the carb can stick and cause this. What do I have to do to fix it?
Mike
VAC Lee
01-11-2007 15:26:10
 Re: VAC Carb in reply to FM, 01-11-2007 09:20:59
Did the oil look ok especially after you ran it or was it off color? On an updraft carb it would be mighty hard for enough gas to get in the intake to effect the oil. Most gas engines will have alittle gas order to the oil and it will get stronger as they wear. I would be more inclined to think that you might have a coolant leak. If you pull the stick while it is cold sometimes it will not show other than over full if the engine has sit for a while. I would drain it and check for coolant. After it sits for a while you can pull the drain plug and if there is any in it it will have settled. Also after it is run the oil will get milky.
Gary Cash
01-11-2007 11:35:32
I have a "new" carb on my VAC but I always turn off the fuel supply when finished with the tractor. I've found that the both the old and new carbs tended to leak fuel when the fuel supply line was left open.
Augie
01-11-2007 09:23:14
Shut the fuel off when you're done using the tractor.
FM
01-11-2007 09:31:49
 Re: VAC Carb in reply to Augie, 01-11-2007 09:23:14
Augie,
Thanks for the idea. I guess I'm looking for more of a permanent fix than a bandaid. What would I be looking for in the carb if I tore it apart? Or just put a kit in and rebuild it and hope it works?
Mike
Augie
01-11-2007 09:36:06
 Re: VAC Carb in reply to FM, 01-11-2007 09:31:49
Replace the needle and seat, and check to see that the float will float. If you're in the midst of some bad cold weather you could have a bit of water in the fuel that's causing the sticky float. Try a bottle of Heet in the tank.
