SC clutch sticking
FWB
01-10-2007 20:30:16
I have 2 SC Case tractors a 1948 and a 1949 with the same problem. While driving or just running the pulley the clutch wont release right away when you pull the clutch lever. What can be done to fix. Also I can't get the engine oil bung uder the clutch housing loose on one. Any ideas without completely wrecking the plug. Frank
C. Amick
01-11-2007 09:27:08
 Re: SC clutch sticking in reply to FWB, 01-10-2007 20:30:16
Could the clutch adjustment plate be adjusted too tight?
wilson
01-10-2007 20:39:59
My DC 4 had that problen. One of the brackets on the pressure plate was broke. Had to split it to get pressure plate put to weld it, Splitting is easy to do with splitting pins. I used to sell splitting pins but sold all stock to Don L who has many case parts. Thats Rusty Acre parts.
