SC Motor
911oldschool
01-10-2007 13:56:13
I just tore into my 1950 SC.(got the tree out of the linkages, and the metal off).
I have some bent Rods, and some busted sleeves.
Was there more than one motor sold with these?
And Is it a REALLY BAD idea to purchase used sleeves?
C. Amick
01-11-2007 09:31:09
 Re: SC Motor in reply to 911oldschool, 01-10-2007 13:56:13
There are two different styles of sleeves and three different bore (piston)sizes. Many used sleeves are pitted really badly on the exterior and hard to get to seal at the "O" ring.
911oldschool
01-13-2007 13:47:01
 Re: SC Motor in reply to C. Amick, 01-11-2007 09:31:09
piston bores on my number 2 & 3 pistons respectively 3.483, 3.496. what are the styles, that you mentioned. I have yet to get a sleeve or piston out of the motor.
C. Amick
01-13-2007 20:20:02
 Re: SC Motor in reply to 911oldschool, 01-13-2007 13:47:01
The later engine blocks had sleeves with 2 exterior "O" rings. The sleeves in the older engine blocks have only one "O" ring. They are not interchangeable. The "O" rings set in grooves in the engine block. There should be part numbers on your pistons. Are the pistons cast iron or cast aluminum? If cast iron, they are likely 3-1/2 inch.
RAiken
01-11-2007 03:22:04
I have 4 SC rusty stuck engines, could get some good parts off them. There was a set of used sleves on ebay.
wilson
01-10-2007 20:43:32
be sure to get sleeves using only one O-ring as later sc had 2 O-rings. Unless you are farming full time with your tractor theres nothing wrong with good used sleeves properly honed.
Larry806
01-10-2007 19:20:33
Where are you located?
911oldschool
01-13-2007 11:58:49
 Re: SC Motor in reply to Larry806, 01-10-2007 19:20:33
I live in Richmond, VA. Will be traveling to N.C. (greensboro) this comming week.
I will try to get the inner diameter of the cylinders today. ( the old ones split... wate got into the cylinders and pushed the walls out)
Larry806
01-13-2007 13:51:00
 Re: SC Motor in reply to 911oldschool, 01-13-2007 11:58:49
I"m in Ohio & have a 49 SC for parts I'd give you what you want off it if you were closer
