VA drawbar - where to find one?
dpski
01-10-2007 09:56:54
Hi folks, I have a VAI with rear PTO, no eagle hitch and I'm looking to put on a rear draw bar. Similar to the one in the photo below. That's not my tractor I just found this photo on the web, not even sure if this photo shows the standard VA drawbar or a homemade one.
third party image
I'm assuming any drawbar from the VA series will work except for maybe the high models?
I'm also guessing the drawbar for a VA tractor with the eagle hitch is different and may not work as well?
I prefer one with a swinging drawbar if I can find one and if it will work on my tractor.
I suppose my friend and I could always weld one up if need be, might spend less in beer to do that than buying an orginal, but I figured I would at least try to find an original or suitable substitute first.
If anyone has any insight to the above questions and/or knows where I might be able to find one of these please let me know.
Thanks,
Don
dpski
01-11-2007 19:10:44
 Re: VA drawbar - where to find one? in reply to dpski, 01-10-2007 09:56:54
Thanks for your help, this place is awesome!!
'53 VAI Guy
01-10-2007 19:37:19
Kestrel's photo depicts the most accurate original style draw bar for a VAI. The very first tractor shows what appears to be a Farmall hitch. My VAI has the Eagle Hitch and I do not see how any other type of hitch would work other than that shown on Kestrel's. If you want to put an Eagle Hitch on your tractor, remember you need room for the cylinder, rock shaft, and lift arms (which by the way are non-swaying). Get out the torches and good luck.
mj
01-10-2007 15:20:26
third party image
Here's the specs - click the link to see more (photo #33) and to enlarge and/or print.
mj
01-10-2007 15:38:56
 Re: VA drawbar - where to find one? in reply to mj, 01-10-2007 15:20:26
Here's a link for the yoke, pin and bracket that you'll also need.
Keith-OR
01-10-2007 14:10:04
"Chicken" posted pictures of VAC drawbar and measurements. Her is the thread of when he posted info...HTH
Keith & Shawn
JGarner
01-10-2007 13:18:20
Case IH site shows these parts in their parts search section by searching on VAC. VAI listing does not show any draw bar but it does show eagle hitch parts. ebay has some of these early in the recent posts today.
arthur
01-10-2007 11:01:50
Neither of the above drawbars are the correct one for a VAC...I don't have a picture of the correct one.
Newton Miller
01-10-2007 10:54:10
the drawbar in your photo is a farmall H or M drawbar should be at least a half million of them around.
Kestrel in CT
01-10-2007 10:42:35
third party image
I'm not familiar with other arrangements other than my own drawbar pictured here.
It has a 1" diameter hole and safe low center of gravity. I use it all the time to haul wagon loads of fieldstone.
Soon I hope to have the rear end all cleaned up and painted like the one in your photo. First I have a brake job and rear axle job to do. Thats why the fenders have been removed.
Hope this helps some. I imagine you'd have to do some serious searching to find what you wanted, or go with the beer/welder technique.
