Farmall Cub speed Control
John Easto
01-10-2007 07:40:39
I have a Farmall Cub FCUB 986 (1946). I have to move the speed control lever several notches,5 or 6, before getting any change in speed. Where can I get information or a drawing of this linkage assembly from the speed control lever and linkage to the carburetor.
C. Amick
01-11-2007 09:37:31
 Re: Farmall Cub speed Control in reply to John Easto, 01-10-2007 07:40:39
The governor could be the problem. It may need adjusted or the governor spring may be weak. I think there is an external adjustment screw.
ken indiana
01-22-2007 02:12:26
 Re: Farmall Cub speed Control in reply to Dave F., 01-10-2007 08:23:22
make sure to oil/lube all the linkages very well between the throttle and the govener, this happened on my 1972 cub and lubeing the linkages solved the problem.
