2590
pwilson
01-09-2007 19:21:44
Engine cranks fine but when I press the clutch the tractor will not go into any of the 4 gears, it only makes grinding noise. I had been using the same day, no problems. Any help appreciated.
pwilson
skosler
01-12-2007 13:16:50
 Re: 2590 in reply to pwilson, 01-09-2007 19:21:44
sounds like one of the spools in the control valve may be sticking and not letting the pressure dump and release a clutch. Check and adjust the linkage first. If that doesn't work, put some gauges on the control valve and check pressures. These things are complicated!
