1070 Hydraulics
Bill1070
01-09-2007 17:18:32
Just bought a 1070 that has hydraulic problems. The tractor has good hydraulics at both of the aux outlets however the 3 point does not work. I have a factory service manual however it does not offer the test etc that I need. Any suggestions would be appreicated. I feel like it is a seal or stuck valve but not sure where to start.
Bill1070
01-09-2007 20:08:09
 Re: 1070 Hydraulics in reply to Bill1070, 01-09-2007 17:18:32
I had thought about the cable but appears to be working. I will check it closer before I go further. The previous owner had welded brackets on the side of the tractor and was using a cylander to raise and lower the arms. I am thinking the problem will be internal.
turbo
01-09-2007 17:52:47
Is the spool of the 3pt valve moving when you move the control lever? If not the control cable could be broken or the roll pin on the arm going into the linkage box is broken. If spool is moving, the lowering spool may be stuck off of it's seat, (front spool under cover on RH side of valve) or raising spool stuck, (rear valve under same cover). This is where I would start.
c hess
01-09-2007 17:48:41
First make sure cable from 3 point control handle is not broken. I think you will have to remove seat an plate under it to replace if that is trouble. I am presently doing that to a 870. Removing seat is easy -only 4 bolts. You might be able to check if valve works by removing floor plate in front of seat. Had a1070 with 7000hrs on it . Was a good tractor. 107 dollars if that is trouble.
