VAC lower end questions.
FiremanJohn
01-09-2007 09:33:54
In the middle of my VAC complete motor rebuild I keep running into questions. First, I never have used the string packing for the rear main bearing. Do I just put a bead of it in the groove or do I really pack it in there. I have 2 bags from the factory with the rebuild kit. That is an awful lot to just lay in there. Second, which way does the middle bearing cap go on? There are no markings on it and silly me did not mark it. There is a flat side and a rounded side. Which one goes on the camshaft side. Thanks guys for the help in advance.
1031D
01-09-2007 18:39:16
 Re: VAC lower end questions. in reply to FiremanJohn, 01-09-2007 09:33:54
You have to take a punch and drive as much of that packing in the block or else it will leak. I learned this the hard way.
VAC Lee
01-09-2007 18:19:59
When you put the cap on it will go on the studs either way, but it will only line up with the main web one way. The holes in the cap are off set just a little. Good Luck.
