Dakota Mike,on that distributor:
jal-SD
01-08-2007 06:48:58
We have converted several SC's & DC's to battery ignition, for the same reasons that you are looking for a change. The best, as indicated by others, is the right angle delco. Our IH dealer's parts man can pull needed parts off the shelf without even looking up the #, there are so many IH's with them still in use in our area. Back in the '50's (when I was a kid) you could buy a distributor from IH that cost less than the repair parts for a mag, so lots of them were sold-we converted our 2 H's to distributor ignition @ that time. (Wish that I would have kept the mags that were in the junk pile when Dad sold out in the early 80's.) The flat IH's & delco's will work on a Case too, but are tight at the oil filter. An IH mag will work, if you want to stay with a mag. The right angle deoco distributors from AC's are the same, we've picked up a couple from salvage yards. If you want to go to 12V, just change the coil. Its been a while since we did the last one, but if I remember right, I think the rotation is opposite that on the Case mag, but all you have to do is switch the wires to the correct firing order. My $0.02 worth. jal-SD)
