Alto-Lite generator
Charles Kunau
01-07-2007 14:40:08
I have an Alto-Lite generator with 3 brushes Model GBM4809B-5 2D. It has 2 wires that hook to a voltage regulator. My question is: If I hook this to a 12 volt regulator will it generate 12 volts
John Saeli
01-07-2007 17:39:50
 Re: Alto-Lite generator in reply to Charles Kunau, 01-07-2007 14:40:08
It can be converted by a shop to 12V.
CENTAUR
01-07-2007 16:20:00
Your Auto lite Generator is a 6 volt,neg.ground,two charge regulator control with clockwise rotation at the drive end.It will put out a max.of 15 amps@ 8 volts.CENTAUR
AllanC
01-07-2007 16:10:40
Actually if it's a 3 brush type the A lead goes to the cutout and there probably is no Voltage regulator, It would have a resistance and a switch or a type of voltage regulator that os actually a hi - low switch.
Walt Davies
01-07-2007 15:04:05
NO!
Walt
JGarner
01-08-2007 08:07:00
 Re: Alto-Lite generator in reply to Walt Davies, 01-07-2007 15:04:05
Walt, please explain your post. I sense some good information I mmay be missing behind this emphatic NO!
