cracked sleeve in 580 ck - d188 engine question
jim in north te
01-07-2007 08:32:42
A while back my thermostat got stuck shut and I cracked the head. The engine still ran so I nursed it back to where I could work on it easier.
There was water in the oil, so I pulled the head and found it cracked. There was also a 2 inch crack about a 1/4 in down from the top of the no. 2 cylinder sleeve. A toolmaker friend of mine made a sleeve puller for me and I pulled the sleeve. There is a groove on the outside of the sleeve that the crack runs along. Is this sleeve bad or is it salvagable? I already have a replacement head and want to put it back together. I have never worked on a diesel engine before. Any comments and advise would be appreciated.
dwag
01-07-2007 16:32:25
 Re: cracked sleeve in 580 ck - d188 engine questio in reply to jim in north texas, 01-07-2007 08:32:42
Normally sleeves crack as you describe due to uneven counterbore in block. Check to see if it is within .002, I prefer .0005 to .001
John Saeli
01-07-2007 08:48:32
The sleeve is junk. Before you replace just the 1 sleeve, consideration should be given to a complete overhaul. For a reasonable price, a complete engine kit is available. What needs to be considered are the total hours on the engine since the last overhaul,; are any other sleeves cracked, or on the way? Keep the Ether can away from the ol'e girl.
