DC puller
Keith Jones
01-06-2007 15:20:51
At what HP do you need to start worrying about breaking drive chains? Are there any remedies to keep from breakng them? Any other tips on creating a high HP DC?
dctom
01-07-2007 05:23:05
 Re: DC puller in reply to Keith Jones, 01-06-2007 15:20:51
THE ONLY TIME CHAINS EVER BROKE WAS WHEN THE COTTER PINS CAME OUT OF THE FIX LINK AND THE SIDE CAME OFF, KEEP GOOD COTTER PINS IN AND KEEP SLACK OUT OF EM TOM
Thad
01-07-2007 04:50:40
I agree with Don keep the slack out and you wont have any trouble with the chains. The only real problem for some building the engine really big. Has been the rear main needs some support for it to hold up with 7" stroke. But thats not that hard to fix up something. Thad
Gene Dotson
01-06-2007 20:19:08
Keep the slack adjusted out of the chain. Loose Chain can break on a hard pull when the slack at the bottom is able to double over and wedge the bottom of the housing. Usually breaks the housing too... Gene
wilson
01-06-2007 17:16:05
the chains are way over 100 hp rating I am fixing to sell my cc puller which is a lot of dc (clutch 4 one sixteenth pistons cam lp head 31 tooth c sprockets etc.) It has got me a wall of ribbons and trophies. We call it the CC from He--
mshultz
01-06-2007 17:06:59
There"s a DC locally that"s probably one of the biggest in the country, and I don"t know of them ever having problems with the transmission other than slipping the clutch when they first started pulling. Also two 600"s that are some of the best division 5 tractors in the country (also chain drive rear), and again - never heard of any problems in the rear as far as breakage.
