will universal hyd/trans fluid damage the clutch d
stephen kosler
01-05-2007 21:20:16
I heard from one dealer that I have to use the high dollar Case "HY-TRANS" fluid because the universal fluid (same fluid I have used in every tractor I have ever owned) will cause the glue to soften and allow clutch disks to come apart. I called another dealer and they said that it only happens when you use "that greenish hyd oil". I have never seem greenish hyd oil and I don't know what they are talking about. I just bought the tractor and changed fluids I used what the previous owner said to use. Should I spend another $200+ and swap to Hy-Trans?
drbunson
01-07-2007 19:54:20
 Re: will universal hyd/trans fluid damage the clut in reply to stephen kosler, 01-05-2007 21:20:16
On our farm we have a Case 930 and a 970. Back in the good ole days we used the "TCH" fluid that our case dealer insisted we needed. Times got tough for a while and we switched to a much cheaper hydro fluid by Mobil. Here we are 10+ years later and we still use the mobil fluid. We have yet to have a clutch or major hydro related problem. Personally I think it's a scam by case to push their product, but your tractor, your call.
stephen kosler
01-06-2007 21:19:32
OK, I doubt that Case makes their own clutch plates. I would assume that a major manufacturer (that makes friction disks for all kinds of different machines for all different companies) makes the clutch plates for Case. If they make disks for all kinds of hyd service why would universal hyd/trans not work? It is formulated to meet "Universal" requirements. I know that Case does not have their own "company" guys in a shop making their clutch disks. Whats the deal?
c hess
01-06-2007 17:46:38
Definatley change to Oil case recomends! ALSO read other oil label closely as some say not to use for heavy loads. Also as someone else said type in Google bar( CASE TCH OIL) an read.
stephen kosler
01-06-2007 10:43:32
sorry, I forgot to mention that it is a 2590 and the oil is used everywhere.
L.C.Gray
01-06-2007 14:13:09
 Re: will universal hyd/trans fluid damage the clut in reply to stephen kosler, 01-06-2007 10:43:32
I saw "...clutch d" in the heading and my first thought was a D model. I realized later that ithe "d" was just where "disks" got chopped off in the title line.
L.C.Gray
01-06-2007 07:53:41
If you are talking about a model D, the trans oil doesn't contact the clutch. The oil in the clutch housing is provided from the engine, not the transmission. The clutch housing should also be drained at each oil change, and oil added back to the engine to bring the crankcase level back up after the clutch housing refills itself
