Serial numbers
Rod in MN
01-04-2007 19:40:01
I have read on here that someone can tell you what year, month and day a tractor was built, where it was build, where it was sold all based on the serial number. Is there a book that will give me this information? If so is the book good for all tractor types or are there separate books for each brand or groups of brands? I am currently working on a LA Case Serial number 4505847. Am also looking for information on a catapeller RD7 dozer sieial number 902980WSP - - "Alaska" is welded on the blade.
Thank you for any assistance that anyone can provide.
dctom
01-06-2007 06:55:20
 Re: Serial numbers in reply to Rod in MN, 01-04-2007 19:40:01
ROD; 4505847 LA WAS BUILT APRIL 8 1941 GAS MANIFOLD STARTER AND LIGHTS,, CHANGED TO DROP CENTER WHEELS APRIL 14 1941 AND SHIPPED TO RANGE COOP FED. NIRGINNA MINN. MAY 3 1941 TOM
Jimmie D. Phelps
01-05-2007 20:48:56
For case L's the ser#'s are not a help as it is all wrong..... .
Brian in Ohio
01-05-2007 04:57:37
DCTom has the build cards for a certain number of years of Case's production. Build cards show when the tractor was built, where it was shipped, etc. If he reads your post, he'll look your LA up for you, and reply with your information.
Merwin in NY
01-04-2007 20:31:02
Rod, go down the left hand column to the "research & info" section, and look for "serial numbers". If you click on that it will take you to where you can look up each individual tractor company's listing of tractor serial numbers. From what you have listed your LA should be a 1941 model. You get that by subtracting four from the first two digets of the serial number (45-4=41). This works till you get to the model's with the 80's serial numbers. Hope this helps, Merwin
