VAC Case
Todd in Mo
01-04-2007 11:33:20
VAC Case pops and cracks at full throttle. I have no timing light, but it idles good and starts easily. Played with jets on the carb with no luck. Could points be off a bit and cause this?
J Heitkemper
01-04-2007 15:31:34
 Re: VAC Case in reply to Todd in Mo, 01-04-2007 11:33:20
Assumming that the tractor has run fine in the past and this is not an old problem ,AND THE TIMING HAS BEEN LEFT ALONE.... With all due respectr to the 1 year old condenser ,,I firmly believe a nother new one will cure the ailment. Been there .,done that .. OR The valve seats could be bad ,and need regrinding ,,Thats My 2 cents ,Good luck Jim
Vac400
01-04-2007 14:09:36
Todd,
What it sounds like to me is the igntion system will need to be checked. Check your point gap, check your coil should have a good spark.I have a VAC and that is what I had found. Also check your flow of fuel from the tank to the carb. You may want to take the bowl assemble out of the tank and clean it.
I hope this helps you.
Jerry
varmint
01-04-2007 12:42:05
how old and leaky ar your plug wires?
Todd in Mo
01-04-2007 14:06:27
 Re: VAC Case in reply to varmint, 01-04-2007 12:42:05
All wires and plugs new 1 year ago along with points and condenser.
Herb dunham
01-04-2007 14:44:44
 Re: VAC Case in reply to Todd in Mo, 01-04-2007 14:06:27
If the VAC has not been used for some time the problem might be carbon burning off at full throttle. I have had this happen with our VAC and the cure was to pull the choke part way out to richen the mixture. This will cool the burning mixture and as you gradually close the choke the carbon will burn off. Make sure you are wearing a hat and don't be pulling a baler with dry hay like I was.
Todd in Mo
01-04-2007 15:01:16
 Re: VAC Case in reply to Herb dunham, 01-04-2007 14:44:44
Thanks for all the help, I will try this tomorrow. Thinking about trading it for a ATV and I would like it to run perfect. It does sit alot so this could be the deal.
