Need help with 800 shift pattern
Camboted
01-03-2007 16:46:24
Can one of you guys please post a copy of an 800 Case COM 8 speed gear shift pattern?? I need to make up a decal so my guys can find the right gears.
Thanks! Ted
Doc Larry
01-04-2007 16:57:30
 Re: Need help with 800 shift pattern in reply to Camboted, 01-03-2007 16:46:24
third party image
I"ve already got a pic taken and on my server. From a 401 but same pattern I believe.
j heitkemper
01-04-2007 15:49:22
Hope Johns help got you in gear ,, Can t help grinning ,recalling the first time my brother and I were trying to figure the 800 out. I once had 38 oliver70 probably one of the earliest to production of the stacked double H Best Wishes ,Jim
John Saeli
01-03-2007 17:21:55
Hey Ted: Check your e-mail. How 'bout a new shift tag plate. We stock them.
Camboted
01-04-2007 06:34:08
 Re: Need help with 800 shift pattern in reply to John Saeli, 01-03-2007 17:21:55
Hey John, I'll bite on the plate but I need some help now. Where is the slot to get it into low range? What is the shift pattern?
John Saeli
01-04-2007 12:08:04
 Re: Need help with 800 shift pattern in reply to Camboted, 01-04-2007 06:34:08
Hey Ted: Basically the pattern is the same as a Comfort King. 1-2-3-4. 1 being to the right & down. 4th being left & up. Reverse way left against the spring & down. This pattern is duplicated for high range or low range. Low range is down, High range is up. There is a path-way between high & low. When in low range, move the stick to a point between 2nd & 4th, & move the lever up into high range. When up in high range, move the lever midway between 5th & 7th, & shift down in to low range. I'll send a pic. Good luck.
