Case 311 B Loader parts needed
Rob at Webatola
01-02-2007 21:58:39
third party image
Case 311 B Loader parts needed. I basically busted up the end caps of one hydraulic cylinder for my loader. Any case cylinder with 2 � ID hydraulic tube may use the same end that is held on with the 4 rods so I could rebuild mine. Anybody having new old stock of these ends or an old cylinder I could robb parts off I would appreciate you contacting me. Below is my original ad. Thanks
Case Hydraulic Lifting Cylinder needed for 311 B I have a 1958 311B loader that one cylinder was off and got hit by the brushog. I need either the entire cylinder or the 2 end caps as they were all busted up. Mine has the inch and a half ram rod with two and Three Quarters diameter tube. The tube is about 35 and a eight inch long and about 43 inch over all center to center with a 1 and 1/4 inch pin. Other models may fit 210 � 480 and up etc. tractor is located in Northwest PA. I may also be interested in another 300 gas engine to rebuild. G1000 Block. Tell me what ya got or email direct or call and leave message 814 789 4937 Thanks Rob
CH
01-04-2007 04:17:14
 Re: Case 311 B Loader parts needed in reply to Rob at Webatola, 01-02-2007 21:58:39
If that is a three bolt starter motor I have motors and blocks. And parts to rebuild or fix those motors. email me for my link
wayne2
01-03-2007 11:59:07
I would think any Hyd. shop would have what you need. Wayne
wayne2
01-03-2007 12:07:15
 Re: Case 311 B Loader parts needed in reply to wayne2, 01-03-2007 11:59:07
I had one of those but mine had a back hoe! Wayne
