VAC motor rebuild info.
FiremanJohn
01-02-2007 20:11:16
OK, I have an odd one. I was dryfitting my sleeves into the block I just got back from being boiled and cleaned. I can get the sleeve perfectly into all but number one cylinder. It is like it is tweaked a little bit and the sleeve just will not fit. Anyone ever heard of this? Thanks guys.
Joey B
01-03-2007 13:35:59
 Re: VAC motor rebuild info. in reply to FiremanJohn, 01-02-2007 20:11:16
I would try the sleeve in another hole. If it works there then the block needs to be thoroughly examined.
Joey
Steve_Md
01-03-2007 09:45:57
I just completed a rebuild and had a simular problem. Check for burrs on the sleeve OD and use a fine flat file and emory paper to finish. Look for burrs, scratches, or gouges in the block mating surfaces and diameters where the sleeve puller might have caused interferences.
John Saeli
01-03-2007 06:20:53
Very common problem. Usually it's the norm. That bore needs to be honed, top & bottom.
